Posted by dAllen158/0 on May 27, 2012 at 18:48:42 from (72.107.147.132):
Trying to bring a 650D back to life. Has benn sitting for number of years, Got it to run good on gas but with a lot of white/grey smoke. On diesel, will run but not fire on #3 cyl. Lot of light grey smoke when running on diesel also. Had injectors rebuilt and injection primary pump was rebuilt and pump was flow tested. Showes good pressure on diesel pressure gage. Compression test on gas side is 90 PSI and and same as other cyl. No blow buy noted on starting valve when spark plug is out and running on diesel. NO bubles in radiator when running. No water in oil. Have interchanged injectors and miss stays with #3Cyl. Lot of unbburned fuel in #3 injector when pulled. How can I check compression on the diesel side? Do I need to pull head? Thanks for any help.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
