Posted by luv2wrench on May 29, 2012 at 18:45:08 from (75.221.49.40):
FARMALL B GENERATOR!?!?! THIS IS MY SWITCH
4 POSTS THAT DEAL WITH THE LIGTHTS? RIGHT. THERE IS A RESISITOR WIRE BETWEEN THE TOP TWO. ONE HAS PATH TO GROUND ON DIM AND THE OTHER ON BRIGHT. PUT WIRE TO BRIGHT TERMINAL AND RESISTOR LET THE SMOKE OUT ITS CLOTH COAT????????
GENERATOR CHARGES WITH NO LIGHTS ON. LIGHTSS ON AND NO CHARGE. 6.5 VOLTS. NEW GEN. NEW WIRING. NEW IH SWTICH. NEW BATTERY.
REAR WORK LIGHT IS WIRED SEPERATE TO THE LOWER TERMIALS. BOTH LOWER TERMINALS HAVE THAT SAME OHMS TO GOUND IN ANY POISTION.
WHAT WIRE DOES THE LIGHTS WIRE GO TO ON THE SWITCH? I GOT THE REAR LIGHT TO THE
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
