Farmall Tractors Discussion Board
Re: IH tractor handcranks ??
Posted by rockhead on January 11, 1999 at 07:33:53:
In Reply to: IH tractor handcranks ?? posted by MJD on January 09, 1999 at 05:48:54:
I had a IH300U with a hand crank (55' or 56').
The battery ignition worked fine (started up right away) as long as the battery wasn't too dead, would work great even when battery was too dead to turn starter motor, and this was at -5 degrees F. This was a GAS version - not sure about diesels.
(Legal notice)WARNING: hand cranking and other uses of tractors may cause injury or death. Seek
advice from tractor dealer.
Post a Followup
: Re: Re: IH tractor handcranks ??
