Re: Super M live pump
Posted by CNKS on June 01, 2012 at 20:36:36 from (216.144.104.128):
In Reply to: Super M live pump posted by CNKS on June 01, 2012 at 19:11:50:
Also the I&T manual says that the driven gear should be inserted with the "tool marks" facing the body. The end of the shaft of this gear has a bunch of depressions on it, I assume that is what I&T means. I put that end in the hole in the body.
