Re: Hydro question for Pete 23, detailed challenging ques...
Posted by pete 23 on June 02, 2012 at 12:04:36 from (74.32.229.231):
In Reply to: Hydro question for Pete 23, detailed challenging question. posted by Curtisk84 on June 02, 2012 at 07:57:58:
Being you have read the principles of operation, are you getting a definate increase in fwd when you get to the blue line on the quadrant. That is the point where the motor swash plate should start to decrease angle and pump swash plate will have already reached it's maximum angle. It would indeed be a good idea to check the servo pressures. It has it's own regulating valve and the pin anchoring the servo's has seals on plus the seals and orfices in the servo's. There is also a o-ring on the pipe end that has a snap ring on it and it can move back and forth some and wear o-ring. Just a few ideas.
