Now you got me thinking. If I have the engine at high RPM the way it is now the speed is very responsive below the blue range(could lift the front wheels off the ground). Once you get past the blue range it does seem kind of sluggish. At full throttle in high range if I suddenly push the lever from blue range to full forward it will not lug the engine (unless a heavy load). It does get to 20 mph tho. I noticed though that while going up a hill at 20 mph when pulling a load the speed would probably drop to 17 mph before starting to pull the engine down. This hydro does have the capability of stalling the engine.
Do the 2 servos share the same pressure or are they seperate? Pump servo is definitely very responsive but motor servo is definitely in question. Will have to do tests with guages when I get a chance, but I got the PTO out and replacing clutches and seals. Then the tractor has to go back to the field for a while. Thanks for the help guys!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
