Farmall 300 hydraulic problem
Posted by futs on June 03, 2012 at 13:14:53 from (67.3.63.245):
My hydraulics were working fine with my Farmhand loader until I replaced a hydraulic hose with a leaky fitting and now I have down pressure enough to lift the front end of the tractor off the ground, but now it won't lift the loader. There is plenty of hydraulic in the reservoir. So I wonder if I might have air in the system. I loosened the hydraulic hose fittings in an attempt to bleed off any air, but that didn't work. Any help greatly appreciated. Thanks.
