Re: ignition problem
Posted by WV Farmall on June 03, 2012 at 16:32:09 from (75.105.7.137):
In Reply to: Re: ignition problem posted by Janicholson on June 03, 2012 at 15:59:02:
The alternator is an AC Delco. The only info on the alternator is 12 Volt Pos. Grnd. 6o amp. Looks to be a model 10SI.
