Posted by Janicholson on June 03, 2012 at 21:05:35 from (96.24.99.126):
In Reply to: Re: ignition problem posted by WV Farmall on June 03, 2012 at 16:32:09:
If it is a Delco 10SI, it will jhave an edge mounted two prong connector for sensing bat voltage (terminal 2), and a excite circuit (connected to terminal 1) the #2 terminal can be connected directly to the big terminal with a short piece of wire and terminal ends. The #1 terminal should be connected to the ignition switch through a 10 ohm 10 watt resistor, or through a clearance marker light bulb, or through a diode, (the diode should have its band facing the ignition switch, this keeps alternator excite current from runnung the ignition, which keeps it running even when shut off. All of these will do the same job, so it is your choice. the big #10 output wire should go to the load side of the amp meter. (not the battery side. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
