Re: SMD D264 Rear Main Seal
Posted by pete 23 on June 03, 2012 at 19:06:37 from (74.32.229.231):
In Reply to: SMD D264 Rear Main Seal posted by Dalrymple on June 03, 2012 at 07:26:27:
Use the felt. It should look oversized and have to
be forced into place without cutting any of it off.
Soak it good either before or after you get it in
the retainer. Try to square up that crooked retainer
best you can and then use a high temp silicone
gasket maker along with the gaskets to take up for
imperfections. Should not be a big deal. Back of
the block is a good flat surface to check it on.
