SMD D264 Rear Main Seal
Posted by Dalrymple on June 03, 2012 at 07:26:27 from (68.159.102.215):
The rear main wasn't leaking badly, but the front transmission seal was. I decided to split the tractor and fix them both, plus the clutch condition was unknown so I could look at that too.
The rear main replacement is what I have questions about. The crankshaft has a spiral groove, the seal was felt, and the retainer is apparently aluminum as it's aluminum colored and fails a magnet test. I've seen the term "white metal" but not sure I know what that means.
The seal retainer bolts were barely finger tight. I mean that literally, as using a regular 3/8" ratchet, it took pretty much zero force to start them out, no "breaking loose" necessary at all.
So, my questions...
Is there a better retainer? Do I need a better retainer?
What is the torque spec for the retainer bolts? Dry bolts in a dry hole? Anti-sieze in aluminum holes? Lock-tite anywhere?
I have the oil pan dropped down far enough to easily disassemble the rear main. I'm assuming it can be properly sealed (new gasket, proper cleaning of course) after I put the tractor back together and get the splitting stand out of the way?
