Re: No Spark on Grandpa's '52 H
Posted by Central Illinois on June 03, 2012 at 19:46:44 from (75.106.115.48):
In Reply to: No Spark on Grandpa's '52 H posted by dstates on June 03, 2012 at 19:26:11:
I bet the points need cleaned or replaced. By what you wrote it might be time for points, cap, rotor, and wires. You already put in new plugs. Don't forget to set the gap on the plugs. While you are in there take the plate off that holds the points and make for sure the flyweights move in the distributor. It wouldn't hurt to put a little oil on them anyways.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
