Posted by dstates on June 03, 2012 at 19:26:11 from (173.27.246.62):
Got the carb back on my grandpa's '52 H, so I'm working on getting some spark now.
It is a 6V battery ignition system. With the ignition switch on, I've got 6V at both terminals at the front end of the coil, but no spark at any of the (new) plugs. What should my next troubleshooting step be? Points, coil, plug wires???
By the way, I also can't get the wire from the coil to the center of the distributor cap out of the cap. The other end of the wire comes out of the coil just fine. Any tricks? I've pulled hard enough on it that the cap starts to pull away from the ignition housing.
