Re: No Spark on Grandpa's '52 H
Posted by stumper on June 03, 2012 at 19:50:19 from (24.247.184.53):
In Reply to: No Spark on Grandpa's '52 H posted by dstates on June 03, 2012 at 19:26:11:
when turning the engine over the voltage should drop on the point side of the coil when the points close if not, check the points for dirt, corotion,clean them and check the gap .020" (match book cover). I have found if the sit for a while, they get so they don't close electricly,and check for voltage at the points, good luck and hope this helps ,stumper
