Re: Farmall A erratic running
Posted by Janicholson on June 04, 2012 at 08:23:31 from (199.17.6.58):
In Reply to: Re: Farmall A erratic running posted by SadFarmall on June 04, 2012 at 07:08:07:
I agree with Sad, It is lilely in the carb itself.
Pull the drain plug on the garb, and make sure there is flow for several minutes (into a can). If so it is likely in the main jet passages. Jim
