Re: Farmall A erratic running
Posted by SadFarmall on June 04, 2012 at 07:08:07 from (112.213.137.176):
In Reply to: Farmall A erratic running posted by CoreyM on June 04, 2012 at 07:03:21:
I'd be checking the fuel system. It may suffering fuel starvation due to build up of dirt in the fuel system. Check fuel is clean and flowing properly through top the carburetor. If it is, then the carburetor itself should be checked and adjusted. I assume it has an H4 magneto? Was the condenser checked and/or replaced?
SadFarmall
