Re: Electrical - won't start - bad ground?
Posted by Andrew Z on June 04, 2012 at 08:45:01 from (64.252.146.234):
In Reply to: Electrical - won't start - bad ground? posted by Royalwapiti on June 04, 2012 at 08:20:22:
Just throwing this out there are you sure your starter is 100%. How is your positive cable, connections on the battery? Can you turn it over if you jump directly to the starter?
Andrew
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
