Re: Electrical - won't start - bad ground?
Posted by Royalwapiti on June 05, 2012 at 19:28:51 from (70.35.11.176):
In Reply to: Re: Electrical - won't start - bad ground? posted by Andrew Z on June 04, 2012 at 08:45:01:
Nope, it doesn't kick over the starter anytime. I pan to remove and test the starter, the solenoid is attached so they will check that too.
Also I may replace the positive cable since I changed the ground cable. The positive is longer and thicker = $$$$.
Thanks guys.
