Re: Cooling system flush question
Posted by rustyfarmall on June 06, 2012 at 09:31:32 from (67.55.162.174):
In Reply to: Cooling system flush question posted by BigTone on June 06, 2012 at 08:54:26:
Get the engine up to operating temperature and then carefully remove the radiator cap and look inside. If the water pump is doing what it is supposed to be doing, you will see the water flowing into the top of the radiator.
Sure won't hurt anything to remove the water header cover and have a look, but if the engine is as full of rust as expected, plan on replacing the entire cover because the directional baffles on the inside of that cover are probably just about gone.
