Re: 806D steering pump problems
Posted by buzzinduzzin on June 07, 2012 at 17:36:27 from (66.220.92.37):
In Reply to: 806D steering pump problems posted by Jacob Yates on June 07, 2012 at 15:58:09:
mcv pump & control valve do steering, brakes, t.a. functions, then lubrication in that order of priority. if you lose hydraulic functions of the mcv the sprag will still pull a load. the only thing the t.a. clutch pack is for is to stop coasting (like the old t.a.'s) the independent p.t.o. drive train runs the mcv pump, hitch pump, and pto pump full time. one more bit of diagnostic info, the t.a. clutch pack will pull a light load. there are some guys on here that are pretty good with these things, they will give you more detailed info
