Re: Low Oil Pressure
Posted by ltf in nc on September 27, 2000 at 21:22:58 from (206.228.215.173):
In Reply to: Low Oil Pressure posted by Skinner on September 27, 2000 at 19:16:01:
Obviously, you have too much clearance somewhere in the oil passages or the tractor is overheating. Go into detail as to what you did for an overhaul. The problem could be as simple as having left a gasket off to not having replaced the cam bearings or installing the wrong size bearings on the crank. Do you know what Plasti-gage is and how to use it?
Post A Followup
: Re: Re: Low Oil Pressure
