1466 hydraulic problem
Posted by Ed pap on June 09, 2012 at 06:42:20 from (184.10.223.77):
I am looking for some opinions - I have a 1466 when you step on the brakes the transmission light will come on and TA will loose pressure and free wheel. it steers fine. I made the mistake of not running thru the pressure checks because I thought for sure i would find something wrong in the MCV valve so I removed it and took it apart and found nothing wrong, I thought for sure I would find a torn gasket or broken spring or something. so now I am scratching my head with this one. one other strange thing - when i hold the steering all the way over it draws the engine down but then if I shift the TA while holding it over the safety relief will make a very loud chatter until I let up on the steering. This is a strange one !
Thanks Ed
