Ok, I went out and checked the cable. Took it loose at both places and it turns freely on both ends when turned by hand. I also checked it by hooking it up at the drive on the oil pump, and started the engine. With the engine running, tte cable did not move at the other end where it attaches to tach.
Does this mean that the old Tach should work? Does it mean that the gears aren't lined up in the drive part on the oil pump?
What is the best way to fix this problem without having to purchase a new "drive" assembly??
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
