Re: New farmall wont stay charged after i shut it off?
Posted by old on June 10, 2012 at 14:58:33 from (209.86.226.58):
In Reply to: New farmall wont stay charged after i shut it off? posted by rbooe05 on June 10, 2012 at 14:34:35:
Would help us help you if you said what tractor you have since there are 100s of model it could be and that can make a difference as to what maybe wrong. First thing I would do is use a meter to check battery voltage when not running and then with it running. If battery voltage is less then 12 volts battery needs to be charged. Then with it running the voltage should be around 13-14 volts. As for the smoke that could be a number of things but probably nothing to worry about. The radiator many of the older Farmall's you just fill till the fines are covered and that is it or yep they will spit some out
