Re: IH 300 Carburetor Questions
Posted by Retired Farmer on June 11, 2012 at 05:58:29 from (207.200.116.5):
In Reply to: IH 300 Carburetor Questions posted by ATF-110 on June 11, 2012 at 04:39:52:
If it is what I think you are describing, some choke plates had a small round disc that was spring loaded to let some air thru when the choke was completely closed. It probably got damaged or someone removed it and blocked the hole off. You might try the dealer or see if you can find another old carb that has the plate still intact.
Today's Featured Article - Restoration Story: Fordson Major - by Anthony West. George bought his Fordson Major from a an implement sale about 18 years ago for £200.00 (UK). There is no known history regarding its origins or what service it had done, but the following work was undertaken alone to bring it up to show standard. From the engine number, it was found that this Major was produced late 1946. It was almost complete but had various parts that would definitely need replacing. ... [Read Article]
