Re: IH 300 Carburetor Questions
Posted by ATF-110 on June 12, 2012 at 09:00:06 from (205.132.74.4):
In Reply to: Re: IH 300 Carburetor Questions posted by D Slater on June 11, 2012 at 05:52:49:
Thanks for all the replies thus far!
I'll just leave the choke plate modification in place for the time being.
More carb questions:
I noted on the top and bottom halves of carb there are casting marks of "56" on the top and "53" on the bottom. The top also is stamped "-56" on the machined mating surface.
What do these markings indicate?
Year of tractor or carb?
The bottom (bowl) half of the carb also has a threaded in brass orifice near the center that sticks up about an inch above the machined mating surface and inserts into a drilled hole in the top half. I don't see this part on any of the carb drawings for the IH 300 Utility. Top casting of carb has brass tag (361525R92).
Do I have a mix and match carb parts?
