It depends some on what you intend to use the tractor for. If you are just going to play with it I would check the sleeves for taper and out of round. If they are close I would put a set of rings in it and take the head to a qualified shop and have it gone thru which means checking for cracks and grinding or replacing valves and seats. If your rod and main bearings aren't grooved or scored and you have decent oil pressure I would throw a set of rings in it and not worry about pulling the crank. That old girl will run that way a long time and run quite well at that. If you are going to work the snot out of it or use it for tractor pulling well then you should probably go the full route. I've taken many an M and H apart and did the head and valves and put rings in and they ran really well and are still running. I guess it depends how much money you want to spend.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
