Re: should i re sleeve my farmall M?
Posted by gbs on June 13, 2012 at 17:02:40 from (66.83.123.242):
In Reply to: should i re sleeve my farmall M? posted by rbooe05 on June 13, 2012 at 12:19:37:
if it don't smoke ,knock, skip and has good oil pressure try a range hotter plug that should take care of the oil build up,as for the ticking it's most likely valve rocker arm noise
