Re: starting a previously stuck engine: precautions?
Posted by mike_sdak on June 15, 2012 at 06:40:51 from (64.68.165.2):
In Reply to: starting a previously stuck engine: precautions? posted by mike_sdak on June 15, 2012 at 04:27:32:
Hey, thanks for the input! I need to pick up a spark plug - NPT adapter to allow coupling the air hose to the cylinders.
I neglected to mention: After removing the rocker assembly, I pushed down on each valve with the end of a hammer handle. Each valve opened and snapped shut. So that variable should be eliminated. If the tappets are frozen (don"t know if possible or not), would that hurt anything on cranking the engine?
