Re: starting a previously stuck engine: precautions?
Posted by Duner Wi on June 15, 2012 at 10:00:14 from (216.226.80.242):
In Reply to: Re: starting a previously stuck engine: precautions? posted by mike_sdak on June 15, 2012 at 06:40:51:
From the way you describe things I doubt the tappets are froze. If they were froze that would not be good . I would say highly unlikely in your case.
