radiator/steering shaft removal question?
Posted by BigTone on June 16, 2012 at 14:27:48 from (166.248.3.220):
Drain plug will not come out so im going to remove the radiator to get to it better and put on a long drain tube.....
I unscrewed the cap on top of the bolster, loosened the bolt at the u-joint and unscrewed the steering shaft before I realized there is a key-way stopping it from coming out and it seems to be stuck in there.....is this the correct way to remove that shaft and any tricks on getting the keyway out? thanks, Anthony
