Re: radiator/steering shaft removal question?
Posted by Zachary Hoyt on June 16, 2012 at 18:23:51 from (173.84.185.1):
In Reply to: radiator/steering shaft removal question? posted by BigTone on June 16, 2012 at 14:27:48:
I have had good luck popping the key out with a small cold chisel. If there are any burrs or lumps around the keyway you may want to grind them off before sliding the shaft out, it makes it easier.
Zach
