If you are speaking of the belly pump you will have to remove the activation arm on the brakes side. If it has tree plumbing on top, that will have to be removed. Underneath the transmission to pump coupler, if it is installed, will have to be removed. Then it is just the 4 bolts holding it. Get help to lower it. It weighs around 100 pounds!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
