Super M Hydraulic Pump Removal
Posted by dpoc on June 17, 2012 at 13:04:31 from (71.89.126.54):
Hello,
I was wondering what steps I need to take in order to remove the hydraulic pump. Is it as simple as removing the bolt and lower the pump from the tractor? If not what other items to I need to remove or steps do I need to take?
Thanks for the help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
