230 farmall starter button HELP
Posted by buzzinduzzin on June 18, 2012 at 15:17:06 from (66.220.92.37):
I have the type of switch that attaches to the top of the starter & when you pull a rod a bellcrank pushes in a button which makes contact with the head of a brass bolt (inside the switch assy. )& a brass knob protruding from the starter housing.It worked just fine when I parked it now it will not make contact, installed a new switch same thing. when we remove the switch & touch the bat. cable to the protruding brass knob it works just fine ???!!!
