Re: 230 farmall starter button HELP
Posted by Lmack on June 18, 2012 at 19:18:20 from (24.131.58.167):
In Reply to: 230 farmall starter button HELP posted by buzzinduzzin on June 18, 2012 at 15:17:06:
See if you can rock the tractor with it in high gear and watch the fan to see if it moves. Sounds like the starter may be locked (not uncommon for C123 engines). If it is locked and you can't turn using a hand crank or by rocking, loosen the two starter bolts and rock it again in high gear until it pops loose. Sometimes you can get it to pop loose without loosing the starter bolts. Sometimes you can pop it loose with the hand crank.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
