Re: Farmall Super A Oil barfing out intake
Posted by rustcollector on June 19, 2012 at 19:14:55 from (166.249.200.152):
In Reply to: Farmall Super A Oil barfing out intake posted by ccaissie on June 19, 2012 at 11:03:08:
Possibly a large chunk of carbon/rust under an intake valve(s)? I would check the oil bath air cleaner oil cup for level just to be sure. What is the compression ratio of the engine? Compression ratio X 14.7 psi atmospheric pressure should give a good approximation of cylinder compression pressure. I.e. CR=5:1 would yield about 70psi. Some of the tractor distillate engines had a compression ratio under 5:1.
