706 pto just stopped
Posted by steve in wi on June 19, 2012 at 20:08:16 from (166.249.132.117):
Over the weekend I was running my sprayer,pto driven
pump.I was running over the last rows off corns to empty the
sprayer out and noticed the pto quit.I checked fluid level
good.the pto shaft in the rear end housing is connected and
spinning.I pulled the test port plug with the tractor running
and no oil came oil,very little.moving the spool didn't,t help.I
don,t have a adapter to check the actual pressure. The whole
unit was rebuild,t this past winter.cut hay with it and all was
fine.i,l have find a fitting,for that test port,not sure if that
spool is stuck or something else.help,need some
direction.thank you.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
