Re: 706 pto just stopped
Posted by caterpillar guy on June 19, 2012 at 20:34:48 from (66.227.141.21):
In Reply to: 706 pto just stopped posted by steve in wi on June 19, 2012 at 20:08:16:
If you have no oil coming out the check plug. The pump is not working or the valve came apart inside. The valve you can check from the bottom by draining the oil and pulling the drawbar off. The pump you have to pull the PTO out. The easiest way to do that is drain the oil and put a pipe over the PTO shaft as you need to tip the front of the unit up to get the suction tube out.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
