Re: Int'l 424 Carb needle valve setting
Posted by The tractor vet on June 20, 2012 at 06:44:40 from (76.212.225.132):
In Reply to: Int'l 424 Carb needle valve setting posted by AG48 on June 20, 2012 at 05:59:31:
If you replace the solenoid there is NO SETTING on the solenoid ya just screw it into the carb with a new gskt and snug it down and plug and play.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
