Int'l 424 Carb needle valve setting
Posted by AG48 on June 20, 2012 at 05:59:31 from (76.255.72.148):
I have purchased a rebuilt carb. for my 424, and boy does it look good. It really looks like a new one.
One thing though is that it has a needle valve instead of the solenoid valve. This is in accordance with the parts book which shows the solenoid valve as an additional item.
I have a new solenoid valve to install but I'm thinking of just using the needle valve instead.
What I need to know is what the initial setting on the needle valve should be. As it came from the supplier the needle is set to one and a half turns open from the seat.
The solenoid is to be set 4 turns open if I use it.
What should the needle valve be set to?
