Re: Int'l 424 Carb needle valve setting
Posted by rustyfarmall on June 20, 2012 at 07:05:23 from (67.55.162.174):
In Reply to: Int'l 424 Carb needle valve setting posted by AG48 on June 20, 2012 at 05:59:31:
Do not attempt to second guess the guy who rebuilt that carb. Install it just as it is. If the engine stumbles or falters under load, THEN, and only then, should you open that screw 1/2 turn at a time until the stumbling goes away.
