Re: Distributor and resistor questions
Posted by mkirsch on June 20, 2012 at 18:30:21 from (67.253.161.186):
In Reply to: Distributor and resistor questions posted by Zachary Hoyt on June 20, 2012 at 18:23:41:
How do you have it wired? The resistor should be between the key switch and the coil.
It's not terribly important to figure it out right now. The coil can stand some 12V abuse.
The coil is somewhat polarity sensitive. If you're doing negative ground, the - should be connected to the distributor.
Don't mess around. Replace cap, rotor, points, condenser.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
