Thank you. I have ordered a kit with all of the parts you mentioned. At this point the tractor is not wired, I have a battery sitting on the floor with jumper cables to connect it to the tractor. I had the - cable to the frame rail and the + cable to the resistor with the other end of the resistor connected to the coil. I am not sure if that is proper or not based on what you said. I am turning the engine with the hand crank. The whole tractor needs to be rewired but if I need to split it I'd rather do that first. I don't need to be able to move the tractor right now, I'm just hoping to get it running so I can find the squeal that the PO described and also see if the hydraulics and IPTO work. I did drain the oil and look at the seasonal disconnect, which seems to be in fine shape so I guess that is not the problem. Zach
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
