Re: 350D voltage regulator problem.
Posted by John T on June 21, 2012 at 07:21:35 from (66.87.0.204):
In Reply to: 350D voltage regulator problem. posted by Kelly MT on June 21, 2012 at 06:51:12:
The pull in or latch in voltage is adjustable to some degree but I dont get into air gap distances or spring tension or tab bending on the internet, my friend Jim might?? When the gennys output voltage (between ARM post and ground) is at x volts higher then battery voltage, the cutout should toggle and latch in.
You might insure the VR has a good ground to the gennys frame and the tractors case/frame, maybe try a jumper wire to a clean shiny spot on VR and Gennys case and tractor steel n see if that helps??
Also remove n wire brush n clean n reattach allllllllllll the connections on VR and Genny
If she charges well and all connections are good and good grounds and condition persists, the VR may have a problem unless you can change air gaps or spring tension to adjust the latch in voltage but sorry I cant do that over the net. Insure the belt has good tension and all good VR and genny grounds n giver her a whirl
John T Departing Zion Natl Park tHIS am headed for Bryce Canyon and Canyonlands and Capitol Reef and Arches Natl Park in the RV GOTTA LOVE UTAH FOR SCENERY
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
