Posted by Kelly MT on June 21, 2012 at 06:51:12 from (216.47.62.63):
The 12v regulator will not close the cut out contact. I have battery voltage on battery terminal and voltage on the generator terminal when running. If I push the contact closed I indicate charge and can see the regulator run the amps down as the battery tops off. It will charge at about 13.8v to 14.2v. If I jumper across the cut out the charging system works good reacting to lighting loads and bringing the battery back up after start up. Any ideas? Thanks PK.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
