Al - It could be as simple as 5th gear is locked out.
You can quickly tell by trying to move the shifter into 5th. If it won't move beyond the center (neutral) gate, 5th gear is locked out.
The "fix" is simple: Remove the special lockout bolt in the left front of tranny cover and replace it with a standard (shorter) bolt.
If that's not it you'll need to remove the tranny cover for peek inside. Possible problems are worn 4th-5th sliding gear, a worn input shaft/gear assembly, or a worn/bent 4th-5th shift fork and rail.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
