I will make the attemptto explain the process and caution. Short version. as the gen comes up to speed it makes voltage due to the residual magnetism in the field poles (iron, not copper). Because it is not connected to the loads and battery (cutout open) the voltage can get high enough to begin charging the battery. the pull in winding on the cutout relay is grounded on one end inside the VR. The other end is connected to the Gen armrture. if this coil is open, the pulin will not work. If the air gap of the cutout is too wide, or the spring tension is too strong, the cutout will not pull in. Once it is latched in, the current running through the cutout relay current winding holds it in. As the generator stops rotating fast enough to charge the battery, the current will begin to flow into the gen instead of out of it. This reversed current fights the pull in current's magnetism, and the relay breaks the connection at about 2 amps negative. If you feel like playing with it, and if it stays latched when pushed in manually, try tightening the air gap of the cutout might be useful. Running the tractor at 3/4 throttle, use a plastic fork handle or such non-magnetic item to carefully and incrementally push in on the cutout contact. If it pulls in on its own from just a little closer, adjust the little gap stop bracket to close the gap just that much. Try it again to see if it now pulls in on its own. If yes, cool. try it with the lid on the VR (it affects the magnetism). Make sure the cutout opens successfully when the tractor is shut off or it will possibly let the smoke out of the generator if it fails to open. Do not get carried away. Jim
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
