Re: I split the 300 and this is what I found
Posted by Bouncer on June 22, 2012 at 14:04:31 from (68.28.138.229):
In Reply to: I split the 300 and this is what I found posted by Zachary Hoyt on June 22, 2012 at 10:45:26:
I would bet a dollar the noise that caused the PO to park it, was from the throwout bearing eating into those clutch fingers and chewing them off. I agree with the others, and go ahead and replace all you can afford. That whole clutch is going to need to be rebuilt. That clutch disk will not hold anything if you put it back in, see how shiny it is. It has been slipped A BUNCH! You can see the marks in it from building up so much heat. Most likely due to someone putting it all back together and not aligning the clutch properly on install, or using bad parts when putting it back together.
