Re: Idle metering jet is missing!
Posted by Janicholson on June 22, 2012 at 19:47:01 from (96.24.99.126):
In Reply to: Idle metering jet is missing! posted by Crazy Red Power in SE-WI on June 22, 2012 at 19:12:17:
Drill it out just a little bigger, then use a square sided (not helical) easyout to remove it. And yes you can use the distillate Carb. Jim
